Sending data from LabView to Raspberry Pi
I want to send data (analogue values) from LabView to raspberry pi. How can I achieve this?
(2,815 Views)
TCP/IP or RS-232 are the common ways.  Then is becomes a question of how to format your data over the bus.
(2,789 Views)
First, please define your use of the term "analog values". Anything over TCP/IP, serial, etc. MUST be digitized first!.
True "analog" data can be received by using analog IO hardware, i.e. you would create a voltage in LabVIEW using a D/A converter  and read it using a A/D converter on the other side.)
(2,751 Views)
By analog values, I mean any numeric values like 24.4 etc.
(2,732 Views)
Thanks for updating the definition. It is important to uses language that is not ambiguous. 😄
(2,723 Views)
