Send signal to ez430
Hi All,
Is there any possibility I can send a signal by labview?
Here is my situation. I use ez430 to transfer data and display them in labview. And I should impelement pause function. That means the connection between end device and access point of ez430 should be cut off. Or there is possibility of losing data.
So I want access point of ez430 can get a pause signal send from labview GUI. Does labview have this function? If yes, could you show me how to do this?
Thx,
Li
(3,237 Views)
Hi Li,
It sounds as though you already have an application that can communicate with your hardware and you wish to modify this to include a pause function.  Is this a correct summary?
What method are you using to communicate with your hardware? E.g. Serial communication using VISA.
Can you post your VI for us to take a look at.
John
John.P | Certified LabVIEW Architect | NI Alliance Member
(3,183 Views)
