ST-LINK/V2 Programmer with LabVIEW (VISA)
Thank you for the solution, love from Québec.
Message 11 of 22
(4,328 Views)
The VIs that are in the image are
Format Into String Function
and
System Exec VI
to make a command that should look similar to this:
"C:\Program Files\STMicroelectronics\STM32 ST-LINK Utility\ST-LINK Utility\ST-LINK_CLI.exe" -P "C:\Users\Mr_Hach\Desktop\program.hex" -rst
If you make this line in command prompt it should work as intended.
Message 12 of 22
(4,326 Views)
Hi Francis M
I have used this VI to write the hex file in micro controller, when i run this Vi i receive these errors
STM32 ST-LINK CLI v3.5.0.0
STM32 ST-LINK Command Line Interface
No target connected
Unable to connect to ST-LINK!
Message 13 of 22
(4,253 Views)
I am using ST Link V2
Message 14 of 22
(4,241 Views)
Hello @anujsaini,
Be carrefull, ST Link Utility has to be closed, divers installed. It should first running with ST Link before to use CLI.
Francis M
Message 15 of 22
(4,222 Views)
I have tested this with ST-Link hardware is communicating properly but when i have tried with CLI using LabVIEW this error is coming.
Message 16 of 22
(4,216 Views)
Before call CLI with LabVIEW, you can directly open CLI and test your command.
Francis M
Message 17 of 22
(4,213 Views)
Dear Francis
hello
I need this vi for programming ARM from LabVIEW. Could I have this vi?
Thanks.
Message 18 of 22
(3,948 Views)
No idea, i'm not a specialist, just a user who had a specific problem, find and share a solution. I think you need open a new discussion.
Francis M
Message 19 of 22
(3,945 Views)
Hi Cisco,
As I am new here and also in the Labview, I wanted to ask you to share the code of this snipped image if it is possible, becasue it is just an image.
I know you already mentioned that you directly share the code but it is only a .png file and does not have information that can import to Labview.
Message 20 of 22
(2,407 Views)
