SR 830 trigger
I am using SR830, and planning to use the TTL out put (at the rear panel) as a trigger source to synchronize data collections. However, this output generates a TTL train, can any here tell me it is possible to exaggerate one TTL pulse one time? If not, we have to buy a simple TTL generator with labview compatibility.
(3,313 Views)
    Basically from reading the SR830 Datasheet, the TTL out at the rear panel is used to sync phase with external devices. Therefore it is a continous square wave. You may have to purchase a seperate device that can do TTL triggering. The National Instruments USB-6009 is a possible solution that works with labview.
JVP
Best Regards,
Jignesh Patel
Principal RF Software Engineer
(3,293 Views)
