SCPI Instrument driver for LabWindows/CVI ?
Is there somthing like a plain SCPI instrument driver for LabWindows/CVI
that works with all SCPI-DMMs ?
Manfred
(4,984 Views)
> Thanks,
> Manfred
SCPI like any other standard is typically non-standard.
You can try to get a DMM driver and it will probably work
for the most part with any DMM. There may be some
slight differences and some features may not work on all DMMs.
I might suggest you look into IVI drivers. These follow SCPI for the most
part. You get the drivers for each DMM you want and then you have a
configuration file that tells the program which DMM you are using.
It then loads the appropriate driver.
Kevin Kent
(4,984 Views)
"Kevin B. Kent" schrieb im Newsbeitrag
news:39F5ECAF.CBC293D5@mail.usa.alcatel.com...
> > Thanks,
> > Manfred
> It then load
> Kevin Kent
Hello Kevin,
thank you for your answer.
Unfortunately there is no specific instrument-driver for the DMM I'd like to
use (Keithley 2700). As I understand this would be the precondition for the
IVI base classes to work. My hope was to find a simple SCPI instrument
driver to get into the advantage of instrument independence. But you are
right, I also once made the experiance that the "SCPI standard" isn't
completely perfect.
Manfred
(4,984 Views)
> > > Thanks,
> > > Manfred
> > configuration
> > Kevin Kent
> Hello Kevin,
> completely perfect.
> Manfred
Manfred,
You could look for a driver for another Keithly model or try one for a
different brand. They may be similar enough to modify easily. I realize this
goes against the idea of SCPI and standards but it is the best we have now.
Good Luck
Kevin
(4,984 Views)
