Running Labview on Laptop
I am using a system designed by someone else to run on a desktop computer, and I need to switch to a laptop, since my application must be portable. The Labview program controls pressure in a fluid system, and does this by communicating wtih a miniLab board through the USB. What are the minimum requirements for the laptop I purchase, (speed, memory, etc) in order to run Labview effectively?
(3,350 Views)
hello
Check out the LabVIEW release notes for minimum system configuration requirements. If you have a version of LabVIEW other than 7.0, you can search for the documention at ni.com/support
Hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(3,350 Views)
