Run-time error
I downloaded the LabView6 driver for Tekronix TDS224 oscillocope but there's a window saying "File"tktds2x0.c", line 607, column 78: Local 'isSerial' was referenced before being initialized". I have downloaded the latest softwares that come with the driver and the settings on my computer should be correct. Please help.
(3,404 Views)
The first thing that needs to be determine is exactly which driver are you using. I installed the LabVIEW 6.0 driver for the instrument and it didn't install the .c file. The .c file comes with Labwindows/cvi version of the driver.
It would also help if you could give me some info on the system. Are you using a GPIB or serial interface, OS, etc. Inlcude any information you consider important.
Diego F.
National Instruments.
(3,404 Views)
