Reinstalling NI software
I INstalled the download for running a PCMCIA-GPIB card on windows XP.  Everything worked marvelously.  Then the computer hybernated, crashed, and will no longer communicated with the GPIB device.  I want to wipe all of the NI software off the disk and reinstall from the download, since I know that works great.  Alas, I can't delete enough things.  When I try to reinstall using the "typical" installation setting in the installation wizard, it does not install anything and the GPIB problem does not go away.  The computer itelf says the file GPIB-32.DLL file is corrupt, and that I should uninstall and reinstall - neither of which I seem to be able to do.
At wits end,
Bill
(3,170 Views)
Hello Bill,
If you have a corrupt DLL, the best thing to do is to remove it manually.  Turn off the computer and uninstall the hardware, then uninstall all the software that you can using Add/Remove Programs.  The National Instruments software will all be under the National Instruments entry in the Add/Remove Programs list.  Then search your computer for the corrupt DLL to make sure it gets deleted.  You can also delete, manually, any entries under Program Files that are associated with the corrupt file.  Once this is clear, reboot and check to make sure the files are still gone, then reinstall the software.  Also, check that the computer crashing did not break any of the hardware you had installed.
Hope this helps.
Angela
(3,144 Views)
