Recommendations for Hi Pot Tester
Hi Guys,
Does anybody have any good recommendations for a Hi Pot Tester. There are three things my customer is looking for even though they are not really essential:
- Good settling time.
- USB or Ethernet connectivity.
- LabVIEW driver.
Like I said, the above are not essential. If you have good recommendations that do not match the above requirements, still let me know; just looking for a good product out there.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
Message 1 of 8
(7,140 Views)
Morning Adnan:
It's been many years since I've spec'd one out. Slaughter is one manufacturer I have used (their slogan used to be Slaughter- The Protesters 🙂 ).
Do you need AC or DC, how much voltage and current? An optically isolated communications port may be a feature to look for. High voltage + PC = smoke.
-AK2DM
Message 2 of 8
(7,130 Views)
Thanks! I need AC with probably 500V and current can be minimal, around 10mA, or even lesser. I already have tried one from Vitrek but really looking for something with the specifications above especially fast settling time.
Adnan Zafar
Message 3 of 8
(7,122 Views)
Adnan:
Are you talking about ramp time to the desired voltage? Settling time does not make sense to me for an AC HiPot test- the voltage will never settle since it is an alternating voltage. Traditional HiPot testing also applies the voltage for a given number of seconds to ensure the insulation is stressed for a sufficient amount of time. Motors, appliances, etc typically get zapped for 60 seconds, at least from what I remember from the systems I've done.
What are you testing?
-AK2DM
Message 4 of 8
(7,115 Views)
Sorry was talking about the ramp time; got the attributes confused there. We are testing some heater coils, and are using the hi-pot to test for a second. This works fine for the test we are doing but sending a serial command, and waiting for the hi-pot tester to run the test is taking about 5 secs (for a one second test) and we are just interested in reducing that time.
Adnan Zafar
Message 5 of 8
(7,113 Views)
I know we have used QuadTech http://www.quadtech.com/ in the past.  Pretty sure they have LV libs.
Message 6 of 8
(7,100 Views)
This one has a 0.1 second minimum ramp, serial port (with optional GPIB??) and a LabVIEW driver (very dated though- v 4)
Look for the Guardian 500VA model.
Wonder why your test takes so long- have you gone through all the settings? I think some units have a post dwell delay after power is removed as a safety feature.
Hope this helps.
Edit- forgot link:
http://www.quadtech.com/products/8
-AK2DM
Message Edited by AnalogKid2DigitalMan on 05-19-2009 01:00 PM
Message 7 of 8
(7,099 Views)
Forgot to mention, you may want to look at Associated Research, nice units, but a bit costly.
http://www.asresearch.com/
-AK2DM
Message 8 of 8
(7,094 Views)
