Reading measurement of a serial port through a USB hub; the VI presents the error: VISA (HEx 0xBFFF072); What does that mean?
The other error it outputs is Old VISA found? I tried reintlizin the whole set of VI's but it didn't work
(3,410 Views)
Error 0xBFFF072 is not a valid VISA error. I assume you meant 0xBFFF0072, which means:
"VISA: (Hex 0xBFFF0072) The resource is valid, but VISA cannot currently access it."
Check this knowledge base article for more details: Error When Opening a VISA Session on a COM Port in MAX
Hope this helps.
DiegoF
National Instruments.
(3,410 Views)
