Reading from Parallel port error
I want to read a 8-bit data from parallel port. I download the sample code, and it shows error -1073807339. I tried to use Port in and port out function, it shows error too. I check the device manager from windows, it shows LPT1 is working properly.
Please help me.
Labview 2011. windows 7.
(3,408 Views)
(3,404 Views)
I read the file already. I connected pin11 pin12 to ground, and downloaded the sample code, but it still doesn't work, same error comes out.
(3,402 Views)
