Reading from PID controller using VISA in Visual Basic
I want to read data from PID controller which has RS-232 interface using VISA support in Visual Basic but
I dont to know the basic parameters that will be read frim the instrument.
(3,467 Views)
Hi PG Student,
There are several useful documents online:
  • KB 2PGCBGT0. Programming VISA Events in Visual Basic
  • KB 2HH9BUQS. Where Can I Find Text-based Programming Examples for VISA?
  • I have also attached a simple program that demonstrates how to do serial instrument communication in Visual Basic (uses Visual Basic 6.0). The example was written to communicate with a NI Insturment Simulator, communicating with other instruments should be possible by modifying the example. The example uses 9
    600 baud, 8 data bits, no pairity and hardware handshaking.
    Hope these will be enough to get you started. Best of luck!
    Kileen Cheng
    (3,467 Views)
