Reading Config Values
Hi:
If I wanted to read the current setting of AutoPoll, how do you do that?
ibConfig() only seems to set the values and there does not seem to be a
global variable that I can read the existing values from. Did I miss
something?
Thanks, Chris.
(3,397 Views)
Chris,
I believe ibask will accomplish your task. One of the options is ibaAUTOPOLL, which will return a zero or one indicating the state of the AutoPoll. You can find more information on this function and others in the NI-488.2 Function Reference Manual. Here is a link: http://digital.ni.com/manuals.nsf/websearch/7F9CFDD677DFE7A48625672B006C4ADB?OpenDocument&node=132100_US
Heather S.
(3,397 Views)
