Read Real Time data From VISA and plot on graph
Decided to do a quick cleanup of your VI.
Message 11 of 23
(3,194 Views)
thanks both of you.
But how can I adjust X -axis scale so that it will show 1000 sine waves per second?
Message 12 of 23
(3,192 Views)
Adjust your history and the min/max of the chart. Turn auto-scaling off. You'll also want to clear the chart when the VI starts.
Message 13 of 23
(3,188 Views)
Thanks..
But still I have a question.
It is sure that the hardware is generating the Sine wave of 1 kHz frequency (i.e. 1000 waves at 1sec).
But it is not actualy showing it over graph. you can see in the image that there is no 1000 waves but very very less of them.
Message 14 of 23
(3,183 Views)
And what did you change your history length to?
Message 15 of 23
(3,180 Views)
I changed my history to 4096.
Sorry, Actualy the generator itself not providing me that much samples per second.
I think I have done the fastest possible reading part. But still it is not showing results as desired.
It was a C-code (generating a sine wave of 1kHz frequency with 16ksps) written just to test if the REAL TIME DAQ is possible SERIALY or not.
It will only be depended on the buad rate? or not?
Do you guys have any suggestions on REAL TIME data aqcuisition and plottings in synchronisation?
Because it is essential for our future task, that we will be generating freqencies having values in MHz. can they be possible to show??
Message 16 of 23
(3,173 Views)
A MHz transfer rate is far higher than any standard com port's baud rate.
You might want to consider an NI scope/digitizer.
Message 17 of 23
(3,168 Views)
But NI Scope is an NI product. Can I use NI Scope in my third party device? NO hah??
Message 18 of 23
(3,165 Views)
Of course you can't but if you can't design an acquisition device with the specs that you need then perhaps you should just buy what you need.
You really need to abandon the rs-232 approach. Look into using high speed USB if you are really committed to an in-house design. Hardware design is really outside the scope of this thread and board.
Message 19 of 23
(3,158 Views)
Thanks Dennis  Smiley Indifferent
Message 20 of 23
(3,154 Views)
