Read Gps Time Position Velocity
I did everything to make the example "readgpstimepositionvelocity" works, but i can't find the "consumebefore.vi". I install my NI Drivers, and i dowload the "Instrument I/O Assistant Version 1.0.1 for Windows 2000/NT/XP" and is not there!. Someone can send to me the "consumebefore.vi" or the exact position?, software version, etc. Im using Labview 7.1
(3,877 Views)
Try searching for that VI in the IOScripter.llb located at ...\National Instruments\MAX\Assistants\IOScripter.LLB.  The KB linked below explains why this subVI and others may go missing.  If that doesn't help, let me know!  Best of luck and have a great day!
http://digital.ni.com/public.nsf/websearch/8491D7DCE8E7305186256D6600596064?OpenDocument
Chris R.
Chris R.
(3,861 Views)
Chris, I have followed your instructions as well as the other posts about the consumebefore.vi problem.  I have installed IIOA 1.0.1 and read the KB you mentioned and tried all solutions and I still can't locate consumebefore.vi.  I know that IIOA 1.0.1 is working because I can place a IIOA object and the assistant starts correctly.  Any more advice?  I am running LabView 7.1 with the latest version of NI-DAQ, etc.
(3,707 Views)
