Re: HP 6032A Driver Read Error
> Hello,
> for the problem you are experiencing I suggest you to use (if possible)
> an utility that permits to detect which are the commands executed at a
> low level, so to understand better what's going on. So, if you are using
> Windows 95/98/NT you can run NI-Spy before running your application.
> In this way you can capture all the low level commands that are sent on
> the GPIB bus, so to detect what's happening when you are not able to
> read properly the data from the Fluke.
> If you are using an O.S. different from Windows, then you should try to
> execute the ibic commands interactively, and see if it is possible to
> reproduce the problem in ibic.
> Best regards
> Cinzia
Message 1 of 1
(4,602 Views)
