RS232 over TCPIP
Is it possible to control an RS232 instrument attached to one PC from another via TCPIP?  Is it simply a case of getting the resource name correct?
I've tried
TCPIP::nnn.nnn.nnn.nnn::ASRL3::INSTR
no luck here!
(4,457 Views)
OK - I think I've found the correct addressing method but still no joy!
TCPIP0::nnn.nnn.nnn.nnn::COM3,488::INSTR
COM3,488 is the default SICL address for my serial port.  I can communicate with this instrument on the host PC with ASRL3::INSTR...
(4,454 Views)
SOLVED
I was using Agilent Visa and had forgotten that I needed to start the Remote IO server....duh!
(4,440 Views)
steveb34 wrote:
> SOLVED
could you tell us what is the solution to control your instrument via
TCP/IP
in terms of :
- programming software on the remote client
- program on the server
Do you have to modify the local program to go remote ?
Thank you in advance ,
FG
(4,421 Views)
It's all pretty staright foward really.
1.  We're using Agilent Via and Agilent's Suite 14 - this is because we're using a parBERT which wont run with NI Visa.  Suite 14 provides a menu option that lets you start an I/O server - simply turn this on (theer's an option to start at boot-up which makes life easy).   The use their interface to add your RS232 instrument -in myt example the address was set to ASRL3::INSTR.
2. On th eremote PC we also use Suite 14, simply go through the process of adding a LAN instrument (it's all GUI driven and very straight forward when you're sitting in front of it) - this will tell you exactly how to address your remore instrument in VISA routines (whether Agilent's or NI's)....you can see the form in a previous note.
So it's all fairly straight forward...
(4,386 Views)
