RS232 RTS
Hi everybody,
   I'm using LV 7.1 and RT module.
   My purpose is to use Digicom Modems LCM 16P with cFP-2020.  These modems should implement a point-to-point communication, between an embedded application running on cFP-2020 and a PC, running LabView application (for tests).
   I have to use 2 wires between the modems.  In this way, I have to perform Hardware flow control in RS232 communication, because, I suppose, the carrier signal should be on (over the 2 wires) only when device has to transmitt data.  I was told by Digicom to use RTS signal (pin 7 on DB9 connector).
   My question is: when I set VISA 232 property, what is the setting's choice? I mean, in flow control I can choose between
       -none;
      -RTS/DTS;
      -XON/XOFF;
   I build a simple test application in which I use RTS/DTS flow control type, but using my scope I observed that the carrier is always present on the transmission line, instead of beung present only during transmission.  In my test app, cFP-2020 sends data, PC receives data, so no overlapping is possible.
   When I set VISA properties for the modem, the carrier signal on modem goes up, and stops when I close (VISA close) the port.
   Suggestins wellcomed!!!
graziano
PS.: I've posted this question in LV forum too.
Message 1 of 1
(3,324 Views)
