RHEL GPIB USB for general user
How can I make a gpib-hs-usb device show up in gpibexploer for a generarl user?
Upon reinstalling a system with  RHEL 5.6 (32bit 2.6.18-274.7.1.el5)  gpibexplorer 2.9.0
gpibexplorer is not able to detect  a gpib-hs-usb device as a general user.
The device can be found if the user sudos first.  This is consistant with 4GHDSAR7.
However, the device is visible to a general user on another system.
(3,599 Views)
Hello Jon,
Have you tried installing ( or reinstalling ) the newest version of the NI 488.2 drivers??
Regards
Mart G
(3,569 Views)
To the best of my knowledge, the most recent version is currrently  ni4882-2.9.0f0.
http://joule.ni.com/nidu/cds/view/p/id/2636/lang/en
Bot the system that shows the device to the general user and the one that does not show the same rpms.
I have tried resinstallation a couple of times. This was preceded by using the uninstall script.
looking for fatal err and warn I did find this. ()
tmp]# grep -i warn *log
clientKalMake.log:WARNING: could not find /usr/local/natinst/nikal/src/clienti488lock-processed.o.cmd for /usr/local/natinst/nikal/src/client/ni488lock-prssed.o
The install log from the system that shows the device to the general user appears to have purged the install log from the tmp diredcoty.
If I were to try the installation process again, would there be something to look for?
Should the device be unplugged durring installation process?
(3,561 Views)
To be clear, I should add that version listed is the one I used.
(3,560 Views)
Hello Jon,
Can you check which kernel version are you using??
Mart G
(3,547 Views)
both systems:
~]# rpm -qa kernel
kernel-2.6.18-274.7.1.el5
(3,545 Views)
