11-16-2015 08:51 PM
11-16-2015 09:10 PM
11-23-2015 04:42 PM
11-23-2015 05:01 PM
11-25-2015 06:02 PM - edited 11-25-2015 06:03 PM
They are custom made instruments that BNC outputs that give a voltage that corresponds to some measurement. What other kind of details can I give you that would be helpful? As for the budget, _this_ is the system being designed so if it exceeds the budget then it probably just won't be built. Thank you for your quick responses so far. Are the terminal block bnc adapters you are referring to like these ones? https://www.google.ca/search?q=terminal+block+bnc+adapter&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjz8sb...
11-25-2015 06:38 PM
