Question about timing an on/off signal for Mass Flow controllers
Hi, Labview community.
Over the summer, I had constructed a LabVIEW VI to control our Cole-Parmer Mass Flow Controllers to regulate the amount of gas entering our system.  We have two mass flow controllers supplying our plasma jet, one feeding Helium and one feeding Oxygen.
I now have a new problem.  We run a Helium and= Oxygen plasma jet.  The Helium is the primary gas flowing.  I now want to be able to pulse the oxygen supply to the jet, meaning, let's say I want 5 seconds of oxygen flowing into the system (oxygen ON) followed by 5 seconds of oxygen not flowing into the system (oxygen OFF).  I want this to repeat in a cyclical fashion of 5 seconds ON, 5 seconds OFF, 5 seconds ON, 5 seconds OFF, etc.
How do I encode for such a system?  I looked through my LabVIEW textbook as well as online, but could find no relevant answers.
Thanks in advance for any help provided.
(2,991 Views)
Hi
so you need a while loop that switches in one case of a case statement
switch oxigen 5 sec on and then off
(so you need the code to switch it on and wait 5 seconds and switch it on again.)
In the other half of the case you only wait 5 sec.
keep this while running as long as you need.
good luck
greetings from the Netherlands
(2,974 Views)
