Query interrupted error while acquiring waveform from TDS3012B
 Hi everybody, its my first time here, I hope someone can help me...
Im  using a GPIB-USB to perform single channel data acquisition from a tektronics TDS 3012B oscilloscope. I am using the single channel acquisition program that come as an example with the labview driver. When run the program I get the following error
Error -1074001665 occurred at TKTDS3K Error Query;
Instrument reports the following:
241:  Hardware missing;
0:  No events to report - queue empty
Possible reason(s):
Instrument Specific Error Occurred.
I am attaching the single channel acquisition programa . Could someone please help me debug this error or tell me what can be the problem, please.
Thanks in advance.
(4,946 Views)
One of our customers has solved the issue just by removing the error query part. Try to check this out and see if it works.
Best regards.
(4,866 Views)
I am encountering the same problem. Please let me know if you solved it!
(4,097 Views)
