Query installed passports
The VISA header defines constants for each interface type. But if a use has a passport driver installed, the intfType value from viParseRsrc might return a different, unknown value. Is there a way to query these values and the interface type prefix or the library to which they belong? In other words, is there a function that can be used to obtain a table like:
"gpib" -> 1
"vxi" -> 2
"some new thing" -> 101
Message 1 of 9
(6,146 Views)
Hello HEG.
Thanks for using the NI forums. Could you please describe your issue in a better way? What VI are you using? What are the parameteres that youre sending? Please be more specific.
Regards.
-- Luis C
Luis CT
Message 2 of 9
(6,112 Views)
Hi Luis,
Thanks for answering. I am not using any VI, just calling the VISA library from C. As I mentioned, when you call the viParseRsrc function, the intfType value tells you about the interface type of the resource. The posible values are defined in "visa.h":
#define VI_INTF_GPIB                (1)
#define VI_INTF_VXI                 (2)
#define VI_INTF_GPIB_VXI            (3)
#define VI_INTF_ASRL                (4)
#define VI_INTF_PXI                 (5)
#define VI_INTF_TCPIP               (6)
#define VI_INTF_USB                 (7)
But if you have another inteface type supported within VISA using an external library through and visible in NI-MAX the the intfType value is not in this list.
The question is: how you can know which are the valid values in a particular instalation and how can you relate them to the resource name?
Hernan
Message 3 of 9
(6,107 Views)
Those are the supported types. What other sort of physical interface are you planning on?
Message 4 of 9
(6,099 Views)
Those are the supported types by default. If you install another passport, new types are supported. For those of you unfamiliar:
"A passport is a plug-in library module that handles the communications with a class of instruments. NI-VISA includes passports for GPIB, serial, TCPIP, FireWire, USB, etc. The passports visible to your installation of NI-VISA can be found in the VISA Options section of National Instrument’s Measurement and Automation Explorer application.""
For example after you have installed the Lecroy VICP paper: "VICP::<ip address>::INSTR" becomes a valid resource name and gets assigned a different interface type value. See for example: http://teledynelecroy.com/doc/understanding-vicp-and-the-vicp-passport
My question is how to query these new interface type values.
Message 5 of 9
(6,094 Views)
Okay. I've never used the LeCroy and assumed it would be a tcp/ip resource. What value do you get from this?
Message 6 of 9
(6,091 Views)
Hello All,
The TeledyneLeCroy Passport uses TCP/IP and the VISA resource will be in form of:  VICP::<IP Address of scope>
Here is a link to an application brief that has more information:  Understanding VICP and the VICP Passport
If you set the scope up as an LXI(VXI11) interface, you can just use the traditional resource:  TCIPx::<IP Address>::inst0::INSTR
I hope this helps!
Leonard Brown
TeledyneLeCroy
Message 7 of 9
(6,084 Views)
Hi Leonard,
Thanks for your response. My question was not really pointed to the Lecroy but was more general. How do you query installed passports and the interface type values from a  NI-VISA installation.
best,
Hernan
Message 8 of 9
(6,081 Views)
Hello Hernan,
OK, sorry.  I do not see a way to do this when using a passport either.
Leonard Brown
TeledyneLeCroy
Message 9 of 9
(6,076 Views)
