01-08-2013 12:46 PM
I'm looking to purchase pumps that I can control via a NI 9205 Module. Any suggestions?
01-08-2013 01:29 PM
Since the 9205 only has analog inputs, you cannot control a thing with it.
You have posted an impossible question to answer. You must provide details on the type of pump you need. I would suggest you do the basic research first and then narrow them down to the ones that have some sort of remote control interface (analog, serial, usb, ethernet, etc.).
01-08-2013 01:34 PM
That should be 9263. My mistake, and I'm looking for a positive displacement pump.
01-08-2013 02:15 PM
That narrowed it down to 2,820,000 results from google. You will need additional parameters for your search.
01-08-2013 04:06 PM
Eldex 3SM or a 3LM?
01-08-2013 04:24 PM
Well, the 3SM says it can be controlled by either RS-232 or 0-5V signal so the 9263 could be used or an inexpensive serial port connection.
