Prologix GPIB-USB with HP4824A using vb6
When I want to read measurements from the Instrument, the HP 4824A, will I first need to sent a command to the controller and then to the Instrument ?
Message 11 of 23
(2,203 Views)
Where can I download this low level GPIB compatibility layer for the driver ?
Message 12 of 23
(2,201 Views)
From links on the Prologix site!
Message 13 of 23
(2,199 Views)
Message 14 of 23
(2,194 Views)
Message 15 of 23
(2,189 Views)
From what I understand is that first I have to send a ++mode (terminated by LF) command, and then a ++auto, followed by ++addr X.
After this I have to send the GPIB commands (read/write/etc), or do I need to do something else ?
Message 16 of 23
(2,185 Views)
I have neither the Prologix nor the HP 4824A.
Is trying something to find out the answer a concept that is foreign to you?
Message 17 of 23
(2,161 Views)
If you can't help then don't respond. I'm asking because I can't seem to figure it out.
I've got the code running, but it won't give me any measurement readings.
Message 18 of 23
(2,155 Views)
Then I would say you don't have the code running?
Have you posted your question to Prologix? You aren't using any NI hardware so your post here is inappropriate. There is no 4824A driver available from NI that I could find so I have no idea what code you have started from. You have not posted any of your modified code either. Did you ever download the GPIB wrapper functions? They are not at the link given by nyc. You should have no problem finding them yourself.
p.s. Now you see why I and others think the Prologix should be used only on hobbyist projects (perhaps that is what you are doing?). The time/money wasted in modifying existing code is more than the small difference in price for a real GPIB controller.
Message 19 of 23
(2,151 Views)
I wouldn't say that using the Prologix is a waste.
The frustration is that the OP is expecting answers to be handed him on silver platter or something.
Try something. Tell us what you have tried and what didn't work.
That is what being an engineer is all about.
Message 20 of 23
(2,143 Views)
