Profibus PA Connection
I'm new to Profibus so I'm not sure what I need to connect a Profibus PA Differential Pressure meter (http://www.yokogawa.com/fld/PRESSURE/EJA/fld-eja110a-01en.htm) or possibly meters to my existing PC104 embedded computer.
My embedded machine has a RS232, RS485, 4 USB, and an ethernet connection and its' running Windows XPe with Labview 2011.  From the searches I've done I noticed that I may need an interface board such as DF PROFI II PCI/PCIe/CPCI/PC104+ http://www.comsoft.de/html/icpe/products/profibus/interfaces/dfprofi2.htm and maybe some kind of coupler to switch from PA/DP.  If all that sounds correct, is the DF PROFI II PCI/PCIe/CPCI/PC104+ a good choice and what would be a good coupler to use?  Could I somehow communicate with the Differential Pressure meter using the RS485 and skip the interface card altogether?  Thanks
(3,360 Views)
Hate to tell you this but Profibus is supported only on the Industrial Communications forum.  Repost your questions here and you should get the answers you need.
Alexander M
(3,349 Views)
I wasn't sure where to start. Thanks.
(3,347 Views)
