I have to write a software to control instruments over the GPIB in VB.NET.
The instruments are a WIKA-Controller (CPC8000), Keithley-Multimeter,
Ruska-Interfaceunit and two Ruska Controller.
A GPIB-Card is plugged in the XP-PC.
There is also an existing software (written in VB6) to control the instruments,
which causes from time to time
some problems.
So I write the software completely new in VB.NET.
The control of the WIKA works fine now, but I have some problems with the with
controlling the Ruska-Instruments:
I post two screenshot of my NI-Spy-Capture (captured when I want to control a
Ruska). The first is a capture ob the old VB6-Software:
First the addresses of
the Ruska (ibdev(0,2, ...)) and Keithley (ibdev(0,16,...)) are defined.
The Send-command initializes the Keithley and after that I test if I can
receive something from it.
Be calling ibwrt(UD0, "cB@@@2...",...) the Ruska-interfaceunit
receives the command and switch to the right Ruska-Controller.
It works.
Now I send the same command with me new software written in VB.NET (see next
capture-image):
Now, every time the Send-function
is called, the function ThreadIbsta() automatically is called.
That is the only different, bevor ibwrt(..) is called. I dont know if it causes
problems to the Ruska?!?
But when I call ibwrt(..) now, I get an error (ENOL - No listener). I don’t see
the error in my code.
Here is the code of my new program:--------------------------
Dim sendstr As String
Dim Board_Cmd As String = Chr(c.LLO) & Chr(c.UNL)
Dim lines As Short
Dim ansAs String = ""
Dim ARRAYSIZE = 18
li.ibfind("GPIB0")
tmp = li.ibdev(0, 2, 0, 13, 1, 0)
tmp2 = li.ildev(0, 16, 0, 13, 1, 0)
sendstr = "*rst"
li.Send(0, 16, sendstr, sendstr.Length, c.NLend)
sendstr = "init"
sendstr = "func 'curr:dc'"
sendstr = "SENS:RES:AVER:TCON REP"
li.Send(0, 16, sendstr, sendstr.Length, c.NLend) ' Select the REPeating filter.
sendstr = "SENS:RES:AVER:WIND 0"
li.Send(0, 16, sendstr, sendstr.Length, c.NLend) ' Set filter window to 0%.
sendstr = "SENS:RES:AVER:COUN 25"
li.Send(0, 16, sendstr, sendstr.Length, c.NLend) ' Set to filter 25 readings.
sendstr = "SENS:RES:AVER:STAT ON"
li.Send(0, 16, sendstr, sendstr.Length, c.NLend) ' Enable filter.
measure_keithley()
li.ibloc(tmp2)
tmpEmpfangen()
li.ibclr(tmp)
li.ibcmd(31000, Board_Cmd)
Befehlsstring = tmpBefehlsstring("C", Controller, 0, _
einheit, tb_Readsensitivität.Text.ToString) ' returns "
CB@@@2P5000000005" + Chr(10)li.ibwrt(tmp, Befehlsstring)
li.iblines(31000, lines)
li.ibrd(tmp, ans, ARRAYSIZE)
The command "
CB@@@2P5000000005" + Chr(10) is the same as in the VB6-Programm.
i don't know where the problem is
Please help
Tanks
