08-07-2007 06:14 AM
08-14-2007 09:19 AM
08-15-2007 05:38 PM
08-17-2007 01:24 AM
08-30-2007 10:30 AM
11-10-2007 11:54 PM
Hi Mark,
I have recently got BSC102 with 2 controller cards installed used to control x-y (2 Linear 150mm stages NST150) am having same problem communicating with the device using LabView and getting error messages. I am not that famaliure with active x but I have followed the demo videos came with it but I got the same error mentinoed earlier in this thread. Moreover I followed your TIP to identify serial numbers of the cards but still no luck. I would appreciate your or anyones help in this regard. If someone can give me a small Labview Active X test code for this device that would make the life much easier for me. I am including an event log below which may help clarify my problem
thanks
immi
Event Log generated 08:45:48 Sunday, November 11, 2007
Thorlabs APT Logging Server (Built: Apr 5 2007 14:40:24).
Server Version:- 1:0:0:17.
08:45:25:0515> [SN 90811894] CMGMotorCtrl::SetHWSerialNum(90811894)
[Internal Code: 11222511; Description: 'Normal' category event.; Notes: No notes.; Extra Info: No extra information.]
08:45:25:0515> [SN 90811894] CMGMotorCtrl::EnableHWChannel(1)
[Internal Code: 23452901; Description: 'Normal' category event.; Notes: No notes.; Extra Info: No extra information.]
08:45:25:0515> Error [Code = 10109]:-
[SN 90811894] CMGMotorCtrl::EnableHWChannel(1); Internal Code = 23462901.
Description: Control HW Communications Disabled
Notes: A software call has been made to a control which is not currently communicating with any hardware. This may be because the control has not been started or due to incorrect serial number or missing hardware.
11-12-2007 04:42 AM
08-30-2008 09:07 PM
We are desinging a elipsometer and we have to communicate the controller BSC 101 with a new application using LabVIEW, Thorlabs tell us that the only way to do that is calling from LabVIEW the activeX of the APT software but i need more information about it, because we are not experts using LabVIEW and we have until november to make the project.
thank you for any information, or any reference
Andres
09-01-2008
03:27 AM
- last edited on
02-05-2025
08:16 AM
by
Content Cleaner
Hi Andres,
Do you have a copy of LabVIEW? If not, then you can download one to evaluate from this page:
Here is a tutorial of using ActiveX in LabVIEW:
Remember, this is not the only tutorial we have on ActiveX. If you do a search on the homepage, you should be able to find more information. Also, LabVIEW itself has some ActiveX examples that you can look into. I would recommend going through the getting started manual of LabVIEW and getting familiar with the environment. You can then try your hand to program ActiveX applications. If you have any questions in the process, post them on the forums. If you have any other questions, please be sure to let me know. Have a great day!
10-04-2008 10:59 PM
We are using the Thorlabs motor controller BSC101, and when we try to use it with labview we have the following error: Error 3006 occurred at property node, and it says that this error code is undefined, so we don´t kwon what we have to do to control the nanomax301 with its driver DRV001 and with its controller BSC101, if someone can help, or can send me an example file, please contact us to: espectometriajaveriana@gmail.com
thank you for your help.
