Hi all,
I want to run a program using only the standard IVI drivers (IVIFGen) as in the attached file.
I can do it using the specific drivers of the function generator (Agilent 33220) but I want to control it using only common IVI drivers.
The problem is that when I run the .VI appears the following problem:
viFgen Initialize With Options.vi<ERR>
Driver Status: (Hex 0xBFFA0011) Primary Error: (Hex 0xBFFA0011) Function or method not supported.
Elaboration: FunctionId: 3, FunctionName: InitWithOptions"
Anybody can help me?
Thanks and regards!
Mensaje editado por UnaiDeusto
