01-15-2009 01:26 PM
You might want to have Context Help turned on. Move your mouse over the Fomat Value function and in the help window, click on the Detailed Help link. That will explain what the %d does. It's amazing how much you can learn by just reading the manual..
As far as the \r\n (not the /r/n as you wrote), the string constant has the '\' Codes Display turned on. You get this by right clicking on the constant. A \r and a \n are a Carriage Return and a Line Feed. They are apparently needed to terminate the command string.
01-15-2009 03:36 PM
thanks for helping me out but i am still blank on the %d command i even read the detailed help but i was unable to find te answer kindly enlighten me it with the command
01-15-2009 09:34 PM
The format %d says to take the numeric input and convert to a signed decimal integer string. The exact help topic is Format Specifiers Syntax Elements. In your code with :"Route:Scan (@%D:" and if you had the number 2 as an input, the function would output ":Route:Scan (@2:"
This is basic stuff in LabVIEW. Did you ever take any of the tutorials I gave a link to?
05-25-2009 07:43 AM
hi
im student, using tha keithley 2010 for scanning GPIB port ....The Kiethley 2010 uses a scanner card with multiple channels (exactly 10 channels) and i want to give the user the freedom to use any of the 10 channels he want how can i do this in labview
i used Keithley 2010 Scan Config.vi but it has a missing subvi called "GPIB Send Message.vi" if u could kindly upload that as well .... waiting for ur reply ..... kindly help me out for my project
05-25-2009 08:59 AM
05-25-2009 10:51 AM
05-25-2009 10:53 AM
Read the thread. The link to the driver is given.
I also gave the link in one of your other posts on the exact same subject before I noticed it was a duplicate. Ask your question once and once only!
05-25-2009 11:15 AM
sorry 4 double posting the same messge....thnks a lot 4 ur reply....yes the link is
http://www.keithley.com/support/keidoc_searchresult?keyword=2010&item_type=All
my drivers for kiethley is installed
im actually not understanding send messege.vi?
05-25-2009 11:18 AM
05-25-2009 11:24 AM
