I have an USB RS485/4 and NI-SERIAL s/w (v1.8) which, about two weeks ago was recognized by the Windows XP machine I'm developing on. I stepped away from the project and just came back but now the device is no longer recognized. I used Troubleshooting Wizard and it says no NI serial devices are attached. When the device is plugged in Windows says initially that a new device has been attached and is ready for use, but then comes back with a second pop-up window message that the device has malfunctioned and no driver is available. If I click on the latter message, XP recommends replacing the device if error repeats (it does). I've been through all the setup / help files, 'add hardware' control panels, and checked the event log for 'niser' errors (none). I have even uninstalled NI-SERIAL 1.8 and upgraded to 3.1, all to no avail. Power cycling the device and rebooting the computer have not solved the problem. I'm beginning to suspect a h/w failure in serial device. Any clues would be helpful.
Thanks in advance,
Greg
