Problem recognize hardware over USB
I'm useing Labview 2016 (64-bit), everything work before switching to a SSD. So everything was fresh installed.
I manged that the arduino and some PI Stages are working fine (shown as com ports).
But i strugel to get the other divices running again. As an oceanOptic 4000USB, and Horiba Spectrometer and a ccd Cam from bluefox.
I tried reinstalling Labview, setting everything back. I thing i miss some packeges. Every device is working with the Orginal software, but not with Labview anymore.
I look up some solution to get MAX to recognize hardware again, but the didn't work out. I have attached a pic of the MAX configuration for most information needed.
Any suggestions ?
Kind regards
(2,829 Views)
Accepted by topic author Spectro89
Solved.
For the OceanOptics i installed Ocean Optics USB4000_vista which seems to be the trick.
For Horiba i have to install a second regestrie fix which work (but still i can use the hardware, it wont show up in MAX)
For MyBluefox cam i have to set direct show up through  myDeviceconfigure.
(2,789 Views)
