Problem Massage when I run getting started VI?
As I mentioned before.
My system is:
Labview6.0
Agilent 34970A
GPIB-USB cable
When I run getting started VI, comes the error message.
(3,516 Views)
You first need to be able to communicate with your instrument in MAX (under Devices and Interfaces) before you start using the instrument driver in LabVIEW. Once you establish communication with the instrument in MAX, use the same resource name (GPIB::your instrument's GPIB address::INSTR) in LabVIEW. You mentioned that the instrument you are using is Agilent 34970A but the screenshots show that you are trying to use a driver for a different instrument (HP34401A). Please make sure to download the correct driver from ni.com/idnet.
Vesna
(3,498 Views)
hi,
just replace the old VISA functions with new ones in your VISA palette.
(3,414 Views)
