Printing to Zebra label printer
Hi there,
I have to print serial numbers with a Zebra Z4M+ label printer. I design Labels with Bar-One
Lite and save them as *.txt files. On each label I have placed a text box with dummy text. Then
I open the text file with notepad and replace this dummy with "%s". This variable I then replace
within my LabVIEW application with the actual serial numbers. So far so good...
I tried several methods to print this string to LPT1. If I print it with "copy myfile.txt LPT1"
via command.com, it works fine. If I try the same operation (identical command line, correct
working directory) with the LabVIEW System Exec.vi, nothing happens. An error is reported (2:
Memory is full)
Printing with VISA write from file.vi causes LabVIEW to crash (cpp error line xxx). After
quitting the error dialog, LV closes and the print starts, but not the complete label is
printed.
When printing with VISA write.vi (Resource name LPT1 or ASRL10::INSTR), no error is reported but
also nothing else happens.
I then tried to print with the old serial port write.vi (serial.llb). When I want to print the
whole label (text file with approx. 600 KB), a error is reported: -1073807339 (VISA: (Hex
0xBFFF0015) Timeout expired before operation completed.). When I send a smaller string (only the
part with the serial number, without all the graphics information), these numbers are printed
correctly.
I tried it also via COM1, and that works perfectly. Unfortunately I have no spare COM port,
because the only one available on my machine is already used to connect some FieldPoint modules
to my application.
Can anybody help me out? How do I have to use the VISA VIs to write to LPT? Any other
suggestions? I guess the solution isn't that complicated because printing directly from Bar-One
Lite to LPT1 and from command.com works fine...I would really appreciate any help I can get!
Before I forget it: I use LV7 on a WinXP machine
Thanks in advance
Kind regards
Achim Traeger
(7,398 Views)
for an easy way to communicate with a printer use the report VI´s. These VI´s are using the printer manager of OS.
Example: see below
Roessner
NI Germany
(7,397 Views)
Hello Achim,
error -1073807339: see link
http://www.ni.com/support/labview/visa/verr2.htm
http://digital.ni.com/public.nsf/websearch/77F74B37A40ABC5F8525645A000300AF?OpenDocument
You can also update your VISA driver.
http://digital.ni.com/softlib.nsf/websearch/8E7D54CA3A1FDECF86256E4D007ED2E0?opendocument&node=132060_US
Regards
TN
(7,397 Views)
Hey guys, thanks for your answers!
To ThorstenRo: Your example works even with the Zebra printer. Unfortunately the function "append file to report" needs about a minute to import the file (ca. 700 KB) to the report. After that the printout works fine. Another disadvantage is that I have to read my original file, replace the variables, and write it again to HD so that I then can append it to the report. (Well, my workaround works in a similar fashion, although that's not very smart)
If I read the file with "read characters from file" and append this text then directly to the report, the undefined error -2147352567 occurs. (See attachment)
To TN: I haven't yet tried to use the VISA function again, although the provided links may contain some use
ful hints.
I tried again with the System Exec function and eventually it worked: The command line has to be: "cmd /C copy D:\MyFile.txt LPT1" (at least on WinXP) So before the print the original file "MyOriginal.txt" has to be read, the variables to be replaced and this altered file to be saved as "MyFile.txt.
...and don't ask me why it did not work at the beginning...I have no idea 😉
Thanks again
Regards
Achim
(7,397 Views)
Hello Achim,
I am quite eager to try out your print_txt-data_V2.vi but it is in LV 7.1. But i am using LV 7.0. If possible could you send me the same which can be viewed using LV 7.0.
I am also working on similar application but the printer i am using is FARGO PRODIGY LABEL PRINTER. I am not sure how to program this printer using Labview as i have seen any useful information regarding this printer.
Appreciate your inputs on this regard.
Bharat
(7,289 Views)
I tried to save it for previous to 7.0 for you, but there are subVI's which were not included; the owner should be able to save it for previous for you 🙂
Best Regards,
JLS
Best,
JLS
Sixclear
(7,273 Views)
HI,
I want to print labels with barcode using seagull bartender and labview and I have to transfer the barcode from labview to the label and print it automatically with labview.
Best regards
Belrhadi yassin
Test and validation engineer-Premo Group
(5,597 Views)
