Pb to program TimeBase on TDS2002B
    I use a scope  TDS200B and i wand to program the TimeBase .
    I use the driver tktds1k2k_MS with Labwondow_CVI and I don't find the command to manage the time base.
    Can you help me.
    Thank
(4,181 Views)
Can you give me more informations? I do not find the tktds1k2k_MS instrument driver. Have you dowloaded it from our website (www.ni.com/idnet)? what is your scope name?
Manuel R
AE dans une autre vie
(4,153 Views)
    I've found the driver on the wed (http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=9075)
    My scope is  a tektronix TDS2002B.
    Thank for your help
(4,148 Views)
Hello ChCO,
      If you are using the LabVIEW plug and play driver, the Configure Timebase VI is under the configuration pallet of the driver.  I found it by using the function panel search.  My search did not yield a timebase configuration VI in the IVI driver with LabVIEW wrapper.  It looks to be a fairly simple VI.
Have a great weekend,
NathanT
(4,132 Views)
Using the IVI scope techonolgy you can't configure this option with CVI. See the screenshot below:
Message Edité par ManuelR le 06-29-2007 08:30 AM
Manuel R
(4,130 Views)
Take a look at the tktds1k2k_ConfigureAcquisitionRecord function. This function configures the common attributes of the acquisition subsystem.  These attributes are the time per record, minimum record length, and acquisition start time.
(4,121 Views)
