PXI-8360 / PCIe-8361
I'd like to control a PXI system with a PC.
Using the NI MAX program, I confirmed that my PC recognizes the PCIe8361 (PCIe x1) installed in the PCIe x16 slot.
The PXI8360 was mounted on the PXI1042 chassis and I confirmed light on of pwr and link.
But NI MAX does not recoginze the PXI system.
Moreover, when I turn on the PC after PXI powered on, it is not boot.
My PC is  optiplex7070 (minitower).
GPIB-USB and USB DAQ works well.
How can I use the PXI system?
Thank you ~!
(2,239 Views)
I solved this problem.
I found that PCIe x16 slot is for graphic card in some main board.
The PCIe8361 is installed in x1 slot and PXI system is recognized on PC normally.
Thank you.
(2,195 Views)
