PLC communication
I'm communicating with a schneider PLC (serial port) through visa  (well configurated : baude rate, stop bits...) but nothing happen in 'read buffer' when the program is running !!!
(5,400 Views)
You have not provided nearly enough information. What protocol (i.e modbus)? What exactly are you writing?
(5,390 Views)
I have already an application works with the PLC (this application sent '?' and receive values) PS: i don't know anything about this application it's given by a supplier.
Now i want to communicate labview with this PLC through visa, the protocol is USB.
(5,386 Views)
USB is NOT a protocol. It is a physical connection.
What are you sending? Are you just making up the commands with the VISA Write? Have you read the manual? Just looking at another applications screen is usually just a waste of time. You have to understand what the other program is actually sending and not simply displaying some action it is doing
(5,366 Views)
I don't have any manual about application, i send the same commands with visa write but nothing received with visa read!
(5,315 Views)
You need the manual for the plc.
(5,308 Views)
