PCIe serial board (8430/8431 etc) latency??
I'm considering using serial boards. Let's say I'm using 4 port PCIe 8430 board. Now, I'm sending 600bytes to each port at the same time. How much latency should I expect? Further, how often can I send those data for each port? 100hz? 200hz? (600bytes for each channel at 200hz means, 120,000bytes per channel per second + 200 times of Windows COM port access overhead per second. Is this achievable?)
Thank you.
SS
(3,695 Views)
Greetings;
While a command such as VISA Write takes about 2ms to execute, there might be a delay between commands simply because of how windows functions.
The PCI-8430 can be set for flexible and nonstandard baud rates from 57 to 1000 000 baud and thus offers data transmissions between 57 bit/s to 1 Mbit/s, which, I believe is for the whole device. Still, I’m unsure and will double-check.
Cordially,
Simon Perez
(3,675 Views)
Thank you for your reply.
It is too bad that the execution time is very long.
2ms is actually not so great. It means I can communicate only 500 times per second.
I'm not sure if it is inherent problem of Windows OS.
Unlike serial communication boards, I can execute read/write of an instataeous value from/to Ni-Daq boards in less than 500um even with Matlab daqtoolbox. I assume that if I use NI API for Ni Daq, that could be even shorter. I kind of wished that level of speed. (I'm not talking about baud rate, but the rate of communication event. Baud rate of 1M is not bad for RS-232.)
Anyway, I think I'll have to research a bit more to find the best solution for me.
One more question. Is there any way to override/bypass Windows so that my software can use the NI serial board directly?
Thank you.
SS
(3,672 Views)
Greetings;
Indeed, latency like that is inherent to Windows as well as most general purpose OS's. Another option is to look into a Real Time OS which might be of aid in reducing that.
About your other question, to my knowledge, there is no way to bypass Windows to do that.
Cordially,
(3,659 Views)
Thank you for your clarification.
Have a nice day.
(3,654 Views)
