PCIe Windows driver missing after update
I am using a PCIe-1427 frame grabber card on a 64bit Windows 10 OS. The card (and associated camera) worked less than 3 weeks ago, but is no longer working. NI MAX recognizes the card but states that Windows is missing a necessary driver, and Windows Device Manager states that the driver is missing.
It looks like there were some Windows updates, which may have caused this. From a Windows standpoint, the solution should be to reinstall the driver, but I have not been able to locate a valid driver. There are zero results for a variety of search terms from https://www.ni.com/en-us/support/downloads/drivers.html.
Does anyone have a solution to this issue and/or know where I can locate the appropriate drivers? Is there a known cause for this?
(1,512 Views)
I'm sorry to bother you now.
When I was browing this communitysection for some help, I took note of your question. Now, I have the same problem about the PCIe-1427 frame grabber card as you mentioned in the year of 2020.
Have you solved the problem now? If so, can you pass on your experience to me.
Thanks  a lot!
Best wishes
Jing
(1,124 Views)
