PCI-GPIB
Hello , I have a PCI-GPIB TNT5004  connected in a PCI slot 5 V 32 bit . My question is if I can connect the board in a 3.3V 32bit PCI slot without damaging the board?Screenshot 2022-09-15 134823.png
(2,185 Views)
Whether or not PCI voltage specifications are supported is determined by the position of the notch.
(2,148 Views)
Thanks for the answer, but it's still unclear to me.
Can I connect the card to the slot below?
The manufacturer says that it can be connected in both slots ,5V and 3.3 V .
He also specifies that only one chip can support both voltages .
The chip on the board is TNT5004. My question is why did he keep the PCB design for a universal connector if it can only be plugged into a 5V slot??
I'm confused, can I connect it to the PCI 3.3V slot?
Thanks for the help!
(2,121 Views)
(2,113 Views)
I have no knowledge of electronics. If you can answer me with , yes you can connect or you can't connect, I would be grateful. 😁
Thanks you !
(2,108 Views)
Unless the computer's PCI revision is very old, a physically insertable PCI card will basically work.
(2,095 Views)
