PCI-GPIB Not detected under Solaris
Got a National Inst. PCI-GPIB bd and in an Ultra 5 it under Solaris 5.6 will not be detected and the /dev/gpib files are not created. ANy Ideas on what causes this ?
(3,280 Views)
Hey Morro,
I would suggest starting with the user manual for the PCI-GPIB for Solaris.
http://www.ni.com/pdf/manuals/321381b.pdf
If you have already started with that, how far are you making it through the installation/verification process and what version of the driver are you trying to install.
I hope this helps out.
Josh P.
Application Engineering
(3,279 Views)
If driver fails to attach, first try is reseat.
Check prtconf -D to see if board is detected by PCI bus.  You should see something like this:
pci1093,c801 (driver name: ib)
NATI,pci-gpib, instance #0 (driver name: ib)
(3,122 Views)
