PC as Multiple device simulator
In order to test a large piece of software, I need to simulate a number
of devices. To achieve this, my simulator needs to capture the address
of the device that the controller is Talking to, and Listening from. How
is this done?
I am planning to use a PC running DOS, and with the simulator written in
C.
Sent via Deja.com http://www.deja.com/
Share what you know. Learn what you don't.
(5,479 Views)
From my experience with GPIB I can think of two ways this might be
accomplished - I don't think it would be possible to change the GPIB adress
on the fly.
#1. Use mutiple GPIB cards with each card set up to the GPIB address of the
device you are simulating - the down side to this is that you could probable
only plug in 2 or 3 GPIB cards before you ran out of IRQs and DMA channels.
#2 Use multiple PCs with each one simulating a particluar device - 386 or
486 PCs (cheap and available) should be up to the task - this has the added
benefit of a more realistic simulation since you have all the loads and such
as the final system would.
Good Luck
Chris
asmith@sced.esoc.esa.de wrote in message <7lt78g$gsg$1@nnrp1.deja.com>...
>is this done?
>C.
(5,479 Views)
