When I try to give the command, RCL1 (recall 1)to the optical switch
(HP86060C) I get a timeout error using Instrument I/O assistant. (Visa
status Code bfff0015)
When I give the same through MAX, I get "Before reading from the
instrument, verify that the GPIB command you are sending is understood
by your device and instructs it to place data in its output buffer.
For information on your device's command syntax, consult the
instrument manufacturer's user documentation."
The instrument responds to *IDN in both the cases.
Also, the switch changes to the recall1 setting, although the output to the command is not read!!
