02-26-2020 11:35 AM - edited 02-26-2020 11:41 AM
Thank you all in advance for your assistance.
I have a National Instruments PCI-GPIB Card 183617G-01 and I am trying to get it installed on an XP machine SP3. This is how it has to be since the instrument software is extremely old(designed to run on NT 4.0 - Hitachi HPLC d-7000).
Can anyone show me where to download the drivers to make the above happen 🙂
The worst-case scenario is to get an ISA slot motherboard and install NT 4.0 and install the NT-488.2M software and the AT-TNTpnp GPIB since this is what the HPLC is designed for, but I would like to get the above working.
I tried to install the PCI-GPIB 183617G-01 card with the XP sp3 machine(as stated above) with the NT-488.2M NT 4.0 (did not work) NT-488.2 v 2.4 (did not work)...windows could not load the drivers as stated in the device manager. Is there a set of drivers in between those that might work?
02-26-2020 06:26 PM
You could try using a software like VirtualBox. I was having an issue where I thought I could try installing a win10 virtual machine on an xp so I could use my labview install on my laptop while still having access to the rs232 port however, it didn't let me use win 10 because the computer didn't have the virtualization tech and the specs were so low. You will probably be able to do Windows NT on an xp machine though. You need VirtualBox 5.0 or earlier I believe it is.
