Ni-Daq Test
I have a NI AT-MIO-16X daq card and there's a problem. When testing the card via Ni-Daq tests everything is ok but when measuring inputs and outputs the analog output channel 0 gives 18 V continous voltage. I think the card is damaged but why does Ni-Daq card test fail?
Outputs are tested with multimeter.
(3,140 Views)
Hi
you can better post this in the DAQ forum : Multifunction DAQ
greetings from the Netherlands
(3,133 Views)
