NRP-Z91 Not Showing in MAX
Hi All,
I have a Z91 sensor that registers within Device Mgr, and using the latest NRP Toolkit and drivers yet NI MAX cannot see it. NI MAX 17.0, NRP Toolkit 4.12
Any help would be greatly appreciated!
(3,370 Views)
Did you perform the troubleshooting steps 1-4 in the manual?  Does the monitor show up under the USB headings?
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(3,357 Views)
I do not believe this third party device should be showing up in NI MAX at all by default. Please see the following in order to get your device working in NI MAX: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x1qzCAA&l=en-US (I'm assuming this is a USB device)
CH
Applications Engineering
http://www.ni.com/en-us/support.html
(3,342 Views)
