NI USB-8452 - Interfacing with 3-wire SPI
I am using NI USB-8452 (master) and would like to communicate with a sensor (slave) using SPI.The SPI bus of NI USB-8452 is a four-wire, full-duplex serial interface. The sensor I want to communicate with has, however, a three-wire SPI (half-duplex interface). This means that it uses single bidirectional data line instead of two unidirectional ones (MOSI and MISO).
Can I configure NI USB-8452 to interface to a half-duplex 3-wire SPI Slave device ? How should I connect the sensor to NI USB-8452 ?
Thanks in advance!
Damien
Message 1 of 1
(4,914 Views)
