NI-Serial inop with executable code
I am using a PCI485 with 4 ports. In LabVIEW 6.02 I can address all four ports. When I create an executable, it works as well. But when I put the executable on a machine without LabVIEW on it, the executable does not work. As long as I specify only use ONE port, the executable works.
(3,516 Views)
Have you installed NI-Serial driver on the target machine?
Have you mapped the ports of the PCI485 in the same manner to COMx as in your development machine?
I have installed some machines with NI-serial, LV runtime and the application. With the porper configuration in the control panel they all worked well under NT and W2K.
Waldemar
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(3,516 Views)
I found that the problem was not the serial card or it's drivers. I am required to install the IVI engine and VISA from my LabVIEW disk, along with the Run Time Engine. Thanks
(3,516 Views)
