NI-MAX requires 32-bit VISA, missing in 64-bit installs
I did a fresh, clean install of LabView 2018 and NI-VISA 18.5. Then I run NI-MAX, and I see the error in the screenshot complaining that C:\Windows\System32\visa32.dll is missing.
Of course, the file is there, it's just that the error message is misleading. A little messing around with dumpbin reveals that nimax.exe is a 32-bit executable (I suppose the giveaway was that it was located under C:\Program Files (x86)\), and despite the name, C:\Windows\System32\visa32.dll is a 64-bit DLL. In fact, (believe it or not), the 32-bit compatibility DLLs are supposed to live under C:\Windows\SysWOW64\. That's right, the 64-bit DLLs are under System32 and the 32-bit DLLs are under SysWOW64. As if multilib weren't complicated enough already.
So, my question is, is there any way to coerce the NI-VISA (version 18.5) installer to install the 32-bit libraries in parallel, so that NI-MAX works? I really like that tool.
(9,380 Views)
One more tidbit: In NI-MAX, if I expand the "Software" tree and then select "NI-VISA 18.5" (see attached screenshot) it shows the path as "C:\WINDOWS\SysWOW64\visa32.dll". That is where I would expect a 32-bit compatibility library to be, but it is inconsistent with the path displayed in the "VISA Error" tree (second attachment), which says "C:\WINDOWS\system32\visa32.dll could not be found."
On my system, "C:\Windows\System32\visa32.dll" and "C:\Windows\System32\visa64.dll" both exist (and are 64-bit DLLs, per dumpbin) but "C:\Windows\SysWOW64\visa32.dll" does not exist.
So I would refine my request to say that the error message should be fixed, and the 32-bit compatibility library should be installed (in "C:\Winodws\SysWOW64") with NI-MAX, which is otherwise pretty crippled without it.
(9,336 Views)
Accepted by topic author Bitdiddle
Have you been able to resolve this issue? I'm not sure if you still have questions on this.
I have NI-VISA 18.5 with the same path you said but I am not getting any errors. If the issue persists you could try force reinstalling to make sure everything is where it should be.
Force Reinstall Non-Working or Corrupt NI Software
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8U0SAK&l=en-US
(9,319 Views)
So "setup.exe /reinstall" definitely helped. The (misleading) error message is gone from NI-MAX, I find visa32.dll and visa64.dll in "C:\Windows\System32" and both are 64-bit binaries (despite the misleading file and directory names), and there is another visa32.dll in "C:\Windows\SysWOW64" that is a 32-bit binary. Better still, an oscilloscope I connected to via USB shows up on the list of "Devices and Interfaces" (first attached screenshot).
But there's still a problem. When I open the VISA test panel and try to "*IDN\n" the scope, the write half of the query succeeds but the read half times out (second attached screenshot). This may be an idiosyncrasy of the LeCroy 'scope, however, because a Tek 'scope plugged into the same USB port did work (third, and last attachment). So I'll accept your solution, thanks.
I still think someone should change the error message that says "C:\Windows\System32\visa32.dll" could not be found when in reality the missing file was "C:\Windows\SysWOW64\visa32.dll".
(9,312 Views)
