NI-MAX doesn.t see my PCI card in Windows 7
I am using an PCI bus M-Module carrier that was working in an XP system but does not work in a Windows 7 32 bit system.  The computer sees the hardware from the Device Manager with no conflicts but NI-MAX does not see it.  I am using VISA 5.0.
(3,248 Views)
Hello bbwpdad,
Where you able to view the  M-Module carrier in MAX on the XP system?  It appears that this is an Agilent device which would not show up in MAX.
David A.
(3,242 Views)
